removing rod end with metal dust cover/spacer - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-24-2006, 01:21 PM
cboy's Avatar
Last journal entry: Finished
I ran into a rod end dust cover/spacer I have not encountered before and need some clues as to how to separate the rod end from the steering rod. This is a Ford type tapered rod end and the circular dust cover or spacer you can see in the picture between the rod end and the steering rod is metal - not rubber. I did some modest tapping on it with a pickle fork but before I start the heavy bashing with the "big tool", I wanted to double check if that is the appropriate method to remove a set up like this. Rubber, I'd know how to proceed. Metal...never seen one before. I can't imagine I won't pretty well wreck this piece when I smack it real good.
Dewey
Always learning...and sharing what I've learned.
Old 01-24-2006, 02:18 PM
abstruse dutch uncle
Maybe use a tie rod remover... the type that grabs the link or arm, and then presses tie rod's stud out of it. There are a few different styles. One of the scissors types or one of the puller types might fit over that.
I usually just use a pry bar to hold tension outward on the rod, and then bang the link or arm where the stud goes through with a mini sledge, or sandwich it with 2 mini-sledges to temporarily distort the hole so the stud pops out.
Old 01-24-2006, 02:29 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Dewey,
Yup yesgo has it right..a puller can be arranged as a pusher to place pressure on the tie rod joint..just back the nut off so it is loose and protects the threads on the tie rod..torque up the puller/pusher and then a good smack should do it..
If that does not do it some heat from a propane torch will help..
OMT
Old 01-24-2006, 03:45 PM
cboy's Avatar
A little follow up...
Turns out what I thought was a metal dust cover/spacer was actually not all metal but rather a metal washer/cap over a thick rubber donut which instead of acting as a dust cover or grease retainer appears to be some sort of cushioning between the two tie rods. By prying rather severely on the rubber donut with a screwdriver I was able to distort and pull it away enough to get the ends of the pickle fork started just enough into the space and eventually whack the thing apart with a small sledge. But I'm still curious. Anybody seen this type of set up and know why the donut instead of a typical rubber grease retainer/dust cover?
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 09:45 AM
Metal Finishing, let's talk about it. MARTINSR Body - Exterior 29 04-19-2011 08:47 PM
"Basics of Basics" Molding repair / metal finishing MARTINSR Body - Exterior 6 07-09-2009 09:47 AM
Question hiem joint / rod end plating western star Suspension - Brakes - Steering 7 10-05-2005 10:33 PM
Removing Interor replacing with sheet metal the ernster Interior 4 03-08-2003 03:09 AM
