Removing S10 Front differential - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2013, 08:05 PM
So i am in the process of swapping a v8 into my 92 s10 4X4, well the new transmission i got will not work with the 4X4 so i am removing it, i did some research and found that it is safe to remove the front differential and take apart the cv axles as long as you have the threaded piece in the wheel bearing, this is true right?
The engine will be removed within the next week or so, so i am going to remove the front differential while the engine is out
So what is the best way to go about removing the front differential, with the engine out? i would imagine start by removing the cv axles then unbolt the differential and lift it out? i have never removed cv axles before, could someone explain how it is done? i removed the bolts on one side at the part where the cv axle bolts to the differential but it wont budge, did i forget something?
First time doing this, and thank you in advance for any help
Old 04-03-2013, 08:19 PM
big gear head's Avatar
High Performance Rear Ends
If you have the early style axles that have 6 bolts holding them in then you will have to smack it with a hammer to break it loose. They kind of press together when you tighten the bolts. The front differential is very hard to remove with the engine in, so remove it now.
The Following User Says Thank You to big gear head For This Useful Post:
Crosley (04-03-2013)
Old 04-03-2013, 10:03 PM
It's a 92 so I would guess earlier style, I don't recall how many bolts, where should i smack it? On the side right where they join together? And it is alright to remove all that right? As long as I leave the threaded shaft in the wheel bearing? How do the cv axles come apart?
Old 04-04-2013, 06:52 AM
I don't know what year they changed the axles, but if you had to remove bolts in the axle then it's the early design. Use a dead blow hammer and hit it on the side where it bolts together. I'm pretty sure that when you remove the boot the CV joint will come apart. I don'[t know about leaving the shaft in the front bearing. I haven't done what you are doing before.
Old 04-04-2013, 10:49 PM
I will give it a try, probably tomorrow, ill let you know how it goes
I was reading and a friend of mine mentioned that it is safe to remove as long as the shaft is still bolted into the wheel bearing, just figured I'd ask to see if anyone here has ever done that before
4x4, front differential, removal, s10, v8 swap
Spindles front, differential rear Blanceman Suspension - Brakes - Steering 2 06-19-2009 07:07 PM
91 S10 rear differential V8S10newby Transmission - Rearend 4 07-26-2008 11:26 AM
8.5 s10 differential? runn141 Transmission - Rearend 1 08-23-2007 12:08 AM
Front to Rear Differential swap adryan16 Transmission - Rearend 2 07-21-2005 10:36 AM
Removing front pannels. Magnus_Jager Body - Exterior 5 02-17-2004 10:08 AM
