Removing silicone and contact cement? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-07-2005, 08:02 AM
Gearhead forever's Avatar
I need to repair a stainless steel fume hood tonight. It has contact cement in the area I need to weld and blend. It may have silicone present as well. Can anyone recommend on what I can use to chemically remove these substances?
Thanks in advance.
Gear.
Old 02-07-2005, 10:49 AM
Beenaway2long's Avatar
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
Carb cleaner or look in the Paint dept at NAPA for some sort of metal prep.
Carb cleaner for the adhsive works great.
Old 02-09-2005, 07:31 AM
Thanks for the tip. We tried xylene as we have lots on hand and it worked like a charm. I had carb cleaner, but didn't try it out. (seeing as the xylene worked)
