-   -   removing speedo gear housing from TH400 (http://www.hotrodders.com/forum/removing-speedo-gear-housing-th400-218066.html)
MJS69 04-11-2012 11:05 PM
Hi all
I figured as long as I'm doing all this work under the car I may as well fix my inaccurate speedo problem. I've never removed the speedometer gear housing from a TH400, I got the retaining plate off, now how do I remove the housing itself without messing it up?
mmerlinn 04-12-2012 04:39 AM
Just grab the speedo cable and pull.
SSedan64 04-12-2012 05:55 AM
1 Attachment(s)
If it's corroded it can be a pain. May need Vise Grips, Channel Locks pliers etc..
Soak it with some PB Blaster or my favorite below. LOL!
MJS69 04-12-2012 12:06 PM
Thanks fellas I'll soak it with some penetrating oil and yank it out tomorrow....
mmerlinn 04-13-2012 01:56 AM
I have had thousands of 400s over the years and never had a problem yanking the speedo out, even when the case was so corroded that there were corrosion holes in the case.
SSedan64 04-14-2012 07:19 AM
Yeah, the TH400 aren't bad.
I'm used to the 200-4Rs' that have the Steel Bullet & Aluminum case, they're a real pain sometimes :boxing: dissimilar metals. :smash:
