removing speedo gear housing from TH400 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-11-2012, 11:05 PM
MJS69's Avatar
Hi all
I figured as long as I'm doing all this work under the car I may as well fix my inaccurate speedo problem. I've never removed the speedometer gear housing from a TH400, I got the retaining plate off, now how do I remove the housing itself without messing it up?
Old 04-12-2012, 04:39 AM
Wiki Edits: 85
Just grab the speedo cable and pull.
Old 04-12-2012, 05:55 AM
SSedan64's Avatar
If it's corroded it can be a pain. May need Vise Grips, Channel Locks pliers etc..
Soak it with some PB Blaster or my favorite below. LOL!
Name:	Penetrating Oil (Small).jpg
Old 04-12-2012, 12:06 PM
MJS69's Avatar
Thanks fellas I'll soak it with some penetrating oil and yank it out tomorrow....
Old 04-13-2012, 01:56 AM
Wiki Edits: 85
I have had thousands of 400s over the years and never had a problem yanking the speedo out, even when the case was so corroded that there were corrosion holes in the case.
Old 04-14-2012, 07:19 AM
SSedan64's Avatar
Yeah, the TH400 aren't bad.
I'm used to the 200-4Rs' that have the Steel Bullet & Aluminum case, they're a real pain sometimes dissimilar metals.
T-400 with no speedo capabilities Chris Champion Transmission - Rearend 4 09-16-2011 09:31 AM
How do you get the inner seal out of the speedo housing on a TH350 Mad_Max Transmission - Rearend 4 04-02-2009 10:18 PM
T-400 speedo gear/housing cornfieldcars Transmission - Rearend 4 04-02-2009 04:53 AM
TH400 with no speedo capabilities Slomotion34 Transmission - Rearend 2 04-22-2008 08:51 PM
TH400 Speedo size Derkyb Transmission - Rearend 0 08-21-2007 06:27 PM
