Removing Spiral Locks On Floating Wrist Pins - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2012, 11:07 AM
To Remove The Spiral Locks On Full Floating Wrist Pins Without Damaging Them I Did The Following. You'll Need Two Small Blade Type Screw Drivers With Thin Blades. Take One Screw Driver And Move The End Of The Lock, With A Small Notch, Away From The Groove. With The Other Screw Driver Slip It In Between The Lock And The Groove In The Piston . Now You Can Take The Other Screw Driver And Start Lifting The Lock Out Of The Groove. I Know These Spiral Locks Are A Pain , But Here Is Where You Need To Exercise Some Patience. Once You've Put A Few In And Removed A Few It Becomes Easier.
Old 04-17-2012, 11:52 AM
SSedan64's Avatar
Spiro Lock Tool
The easy way to remove/install them. >> http://www.lockintool.com/ without damage.
Old 04-17-2012, 12:09 PM
327NUT's Avatar
Your first post and you're giving lessons?.........the hard way? Geeez just do as SS says and get the proper tool.
Old 04-17-2012, 08:53 PM
Last journal entry: My Last Hot Rod
Gee
I've been using a Ball Peen hammer and a cold chisel
Old 04-18-2012, 12:39 AM
327NUT's Avatar
Hey....now those are tools!! no spiral lock in the world can stand up against those
Wrist Pins 80camaroguy Engine 4 04-01-2011 07:24 AM
spiral locks GMR Engine 7 02-15-2008 08:17 PM
Floating Wrist-Pin Question bluesman123 Engine 3 07-17-2006 09:45 PM
Wrist Pins Canadian Charlie Engine 6 07-11-2005 01:18 PM
full floating wrist pins 406 ss monte Engine 8 12-29-2003 09:04 PM
