Removing spot from convertible top? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2012, 01:56 PM
BigAl_50's Avatar
New Member
I have 1968 Mustang convertible with a black top. There is a white spot (almost appears it's been bleached) on the top above the passenger seat about 9" in diameter. It is in the fabric and not something that can be washed off; any suggestions on how to conceal or camouflage this? The car is a driver; not a show car. Thanks.
Old 02-03-2012, 03:20 PM
DanTwoLakes's Avatar
Wiki Edits: 22
Those tops are vinyl, so get some SEM black dye and touch up the spot, or dye the whole top. You can buy it in aerosol form or spray it with a spray gun. You will need to follow the instructions and clean the top with SEM cleaning products, but you can get some really good results.
How to spot a Wisconsin guy with a DUI cboy Off-Topic 16 11-01-2009 04:40 PM
dry spot benchracer1 Body - Exterior 3 01-24-2009 09:54 AM
Flat spot fred56 Engine 4 07-20-2007 04:50 PM
removing camaro engine by removing sub-frame bullheimer General Rodding Tech 7 04-23-2004 02:46 PM
350 in L6's spot 62PTCruiser Engine 2 07-06-2002 05:03 AM
