Removing Spray Adhesive - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-12-2010, 03:40 PM
Hope everybody is keeping warm up North. I am working on a boat which I have removed a heavy vinyl liner from the interior hull. I plan to use an epoxy primer and paint but need to remove the spray adhesive residue, I do not know what adhesive was originally used.
I have tried paint thinner with minimal results. I have been told to try WD-40, lighter fluid, and kerosene. Any other recommendations would be greatly appreciated.
Thanks.
Capta1n
Old 01-12-2010, 08:16 PM
54merc's Avatar
Stallions Auto Interiors
Lighter fluid will work, but don't spend your money buying it as lighter fluid. Go to your local hardware store and look for "Naptha", it is the same as lighter fluid and you can get a gallon of it for around $10.00 witch is cheaper the a can of lighter fluid witch is around $2.00 - 3.00 for a small can. I use it to clean dirt and remove adhesives from vinyls. It will not harm the vinyl and it evaporates quickly.
Old 01-12-2010, 08:40 PM
Jon's Avatar
Jon Jon is offline
Hotrodders.com Administrator
Wiki Edits: 7314
This should go in the Contact adhesive wiki article. I've added a link to this thread in the article. Please add/update accordingly. Thanks.
Old 01-12-2010, 08:57 PM
302 Z28's Avatar
Xylol available at Lowes or Home Depot.
Vince
Old 01-12-2010, 10:35 PM
DanTwoLakes's Avatar
Wiki Edits: 22
Xylol or mineral spirits will take off most contact adhesive. Xylol is more expensive but works a little better. You'll have to work at it if it is old and very dry.
Old 11-10-2011, 01:02 PM
I have found Krud Kutter (from Home depot) to work on all the items on it's label which are Adhesive, caulk, foam, mastic, silicone, roofing tar. It states it's biodegradable. Best to wear gloves when using the product. For me it worked great for removing old labels and adhesive from double sided tape.
Old 11-17-2011, 01:12 PM
Wiki Edits: 22
You can try anything you want, but the solvent for Top and Trim contact adhesive is mineral spirits or Xylol. Nothing else works better.
Old 11-20-2011, 06:04 PM
Can't spell custom without CUS
I strongly recommend NOT to use any oil based product for removal. They will affect the adhesion of your impending paint job.
If the residue is hard and/or brittle scrape it off. Heat will soften it some so it can be removed easier by this method. BUT, be cautious with heat around fiberglass, or it may burn to the ground!
Good luck
Old 11-20-2011, 06:15 PM
Wiki Edits: 22
While you are correct, we are talking about removing Top and Trim Contact adhesive from fabric, vinyl, leather, and Ultraleather. There isn't going to be any paint sprayed on a car seat.
Spray adhesive questions cboy Interior 8 10-30-2009 10:59 PM
3M Super 77 adhesive spray vintage guy Interior 7 04-20-2009 02:53 PM
Spray Gun for Adhesive S10Fan Interior 3 07-29-2005 11:00 PM
Which Spray Adhesive? Dave E Shank Interior 13 12-26-2003 02:03 PM
spray adhesive? nova33 Interior 2 06-15-2003 09:57 PM
