removing a starter drive 64 T-bird - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2009, 11:08 PM
71-78malibu's Avatar
Faster than the speed of stink
How do you do it? I got the starter out but unsure how to get the drive off.
Old 08-08-2009, 03:13 PM
T-bucket23's Avatar
Wiki Edits: 26
On most of those older starters you take out the 2 through bolts and the nose will be able to be removed. There is usually a smap ring that you will need to remove in order to slide the drive off the shaft. If it is a single wire starter, if I remember correctly you need to remove a roll pin that holds the actuator arm so you can slide the drive off.
Chet
Old 08-16-2009, 07:47 AM
The easiest way, put starter in the vise snug, take off the back cover band( just loosen up screw not all the way off) cover band will slide off. remove top cover, remove the pin from the yoke arm (at the top) this will relieve tension when you take out the 2 thru bolts ( these are the bolts that are at the rear of the str) when u take them out hold complete str still together because if it springs on u you have got a little more work then anticipated. now tap the front nose cone (housing) until it comes off, by still not letting it (str) spring apart on u. then lift up the yoke arm (fork) out of the way then there is asnap ring cover slide off then knock off the snap ring (half shaped moon) don't loose it, then slide old bendix drive off. just reverse and u should be good to go! If u unspring everything let me know and I will explain easiest way for u, good luck, Dana
starter woes greenhj Electrical 3 06-20-2009 10:22 PM
SBC 400 Starter problems weedy64 Electrical 3 05-07-2009 01:03 PM
yet another post with starter problems 1989gta Electrical 10 10-23-2008 09:06 PM
Starter Bolt Hole Fix? Gokussj5okazu Engine 21 12-12-2006 04:26 PM
Removing flywheel to converter bolts in a 1958 Chevy Impala 348 Cast Iron Powerglide 1958imp348 Transmission - Rearend 9 11-22-2004 03:18 PM
