Removing sunbaked suface rust before priming. - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2004, 07:14 PM
jcarter's Avatar
Is it necessary to get every bit of surface rust and or old primer off of the roof of my car before epoxy primer? I am using 60 grit on my random orbital sander.The roof is now about 70% bare steel and the rest is either old primer or baked on rust,not pitted or anything,and is smooth across the surface.I can't get the last off this stuff to come off very easily with this sander.I can't use a blaster of any kind in this situation.I tried a wire brush on a grinder, but it just kind of polishes the surface and doesn't take off any more either.A course flap type disc in a grinder would probably make strips and streaks because you couldn't hold it flat enough. I wonder if I go over it a couple more times with say 100 grit on my orbital to smooth it a bit more, if I would have any problems with my epoxy primer lifting or something? What do you guys think? Thanks for any help.
Old 03-10-2004, 08:27 PM
poncho62's Avatar
Wiki Edits: 5
If you can't get it blasted, I would get as much rust off as you can. Then give it a good wipe down with a solvent like laquer thinners to get most of it out, and then give a few good coats of epoxy primer.
Old 03-10-2004, 09:05 PM
302 Z28's Avatar
I would give it a spray of Ospho, let it sit overnight, sand it down, wipe it with prep sol then primer.
Vince
Old 03-10-2004, 09:38 PM
jcarter's Avatar
Just spent a couple more hours working on it.Found some 50/60 grit pads in my supply that are working a little better.I've got a few little dents and dimples to get fixed up on the roof and filler to put on where I've patched holes on the lower body.I'm putting the bondo on under the epoxy primer, so will have to do all of it before I prime. I have lots of POR15 Metal Ready and was wondering if I put that on the roof on these areas of light rust, if yhat will create any problems with the epoxy primer?
Old 03-11-2004, 06:04 AM
302 Z28's Avatar
Isn't POR15 a paint like substance? I would prefer Ospho in your situation to POR15.
Vince
Old 03-11-2004, 08:21 AM
302, The POR-15 metal ready is the same thing as ospho (pretty much the same anyway). Its the company's version they want you to use with their POR-15 paint. I think he'll be able to use it the same way as you say to use ospho.
Old 03-11-2004, 01:52 PM
tundrafiend01's Avatar
Last journal entry: No More :(
I have the same problem with the hood on my imp. When you say Ospho metal treatment, is it this stuff or something different?
Thanks in advance,
g
Old 03-11-2004, 02:12 PM
Yep, that's the stuff, but it comes in other brand names. But that price is pretty high. I bought some Advanced Auto Parts for about five bucks a bottle. I don't remember what brand it is though.
Old 03-11-2004, 02:36 PM
Enrust
Anyone have any experience with this stuff? Just curious if its worth the money to have a rust converter and primer in one?
Old 03-11-2004, 02:52 PM
crash3432's Avatar
your ?
Yes that is very good i would use it on my own vehicle
CURTIS BARNHILL (chevy man)
Old 03-11-2004, 10:47 PM
One More
Did some searching on the Advance Auto Parts web page and found some stuff called Mar-hyde rust converter. Do any of you know if this stuff is along the same lines as the Ospho?
Thanks,
g
Old 03-12-2004, 06:43 AM
I'm sorry tundrafiend. I meant to look at the stuff I bought at Advanced, but it totally slipped my mind (seems like a lot of things do lately).
I don't think the Mar-hyde converter is what I bought. Basically, what you are looking for is Phosphoric acid. It's generally a blue or blue green liquid. Doesn't come in a spray can as shown on the Advanced auto part website.
I just found this site and it looks like this guy did some serious research, and you may be able to better understand which product is most suitable for your application.
http://www.geocities.com/goodytommy/rust/
Old 03-12-2004, 08:47 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
Jcarter, go ahead and sand all the rust off before you put anything on it. Then spray a good urethane primer. And your set to go.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
Old 03-12-2004, 12:29 PM
jcarter's Avatar
Troy-curt thats probably the best advise. I am finally down to what looks more like tarnished metal than a rusty area.If this is primed, do you think there would be any long term adhesion problems?
Old 03-12-2004, 01:39 PM
troy-curt's Avatar
No. Just use a two part urethane primer sealer.
Troy
_______________
