Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Removing upper control arm on a 1967 el camino
Old 06-30-2010, 09:34 AM
joe_padavano joe_padavano is online now
I've done this many times. I usually just leave the shock in place. It does a fine job of holding the spring and lower control arm in place, thought I do usually support the car under the lower control arm to keep the spring compressed. It helps to get the ball joint stud back into place.
