Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Removing upper control arm on a 1967 el camino
Old 06-30-2010, 10:34 PM
67Elcamino's Avatar
67Elcamino 67Elcamino is offline
Thank You
Yes now I recall to put a jack under the lower arm to keep the spring somewhat compressed. Should the ball joint come right off or does it have to be pried off with a fork.. I usually tend to hammer the crap out of them outto frustration.. Just wondering Im using a ball joint splitter, turned it many times and its not popping out just dont want to risk ruining the ball joint
