Removing vinyl top on nova - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-04-2005, 10:45 AM
On my 71 nova I have almost all of the major body work completed, new quarters, fenders, and major dents, etc. I am at the point where it jsut needs some fine tuning and straightening. My question is how much work will be involved in removing the vinyl top. I was originally going to leave it on but it is now all dry and cracked so I am going to remove it for good. I like those novas better w/out them anyways. It appears it is jsut glued on and I assume I will have studs or holes where I remove the trim. Does the vinyl go under the windsheild? How big of a b**** really is this job?
Old 10-04-2005, 10:58 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Basically involves sweat.. just start peeling a heat gun can help and when you get it off you will need to sand the top to recieve paint..it just goes under the trim so you should not need to remove the glass..
OMT
Old 10-04-2005, 11:17 AM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Not sure on the Nova but the Chevell's have a row of tabs along the bottom of the sail area and below the back glass that need removing, Also, The trim piece for the rear window glass is another issue.
You willl also have some filling to do at the top/sail weld area as they don't usually finish these out at the factory. The drip rail trim will go back fine,the rear glass will need a different piece or just finish it out and paint.
Just to clear up "back" glass, I'm refering to the 1/4 glass not the actual back window. It's fine. Sorry if I confused you. I do it to myself ALL the time.
Old 10-05-2005, 04:38 AM
astroracer's Avatar
Also be ready to clean up a lot of rust. If the top has been on the car since new it's a good thing to remove it. Let us know what you find when you get it off...
Mark
Old 10-05-2005, 11:31 AM
I'll let ya knwo what I find, hopefully not too much. It has always been a garage kept car even before I got it and there are no rust bubbles in the vinyl so I hope it won't be too bad.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
paint under vinyl top mitmaks Body - Exterior 7 04-15-2005 12:11 PM
1972 nova targa top 442 chevy power General Rodding Tech 4 11-08-2003 03:58 AM
Re-using a vinyl top El Retardo Body - Exterior 1 08-09-2003 12:29 PM
