Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - removing wavy factory leadwork?
Old 11-06-2005, 10:30 AM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Hotrodders.com moderator
Wiki Edits: 3
Minor waves
From what is said these are minor waves that woudl be visible in the finish..On something like this a glazing material or high build primer may be the way to go..Apply and then block out the section till it is smooth..this may take a guide coat or two to get right..Probably not a lot of fill is needed to get rid of the waves..The idea of using a body file to take down a high spot is good also..
OMT
