Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - removing wavy factory leadwork?
Old 11-28-2005, 09:54 PM
crashtech's Avatar
crashtech crashtech is offline
Technician
Last wiki edit: Epoxy primer
Wiki Edits: 17
I've seen adhesion loss of filler over lead before. The problem went away when I let the filler cure longer. I would make sure that the filler used has the extra adhesion promoter like Evercoat's ZNX-7. I believe some other filler manufacturers are coming out with something similar now, too. Of course, spraying epoxy first would also be an excellent method if time allows.
