Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - removing wavy factory leadwork?
Old 11-29-2005, 11:48 PM
62galaxiguy's Avatar
62galaxiguy 62galaxiguy is offline
When i stripped
the car the sail panels were wavy but the lead had no adhesion problem.But the was a circular spot in the center of the roof about the size of a quarter that was peeling away from the edge..I epoxy primed it and will have togrind out the lead( or use heat to melt it but im afaid the heat will effect the epoxy primer on the rest of the roof..What would you do?
