Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Removing Wheel bearing hub on 1997 Saturn SW1
Old 03-12-2012, 07:39 PM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
Remove rhe entire assembly. Take it to a qualified machine shop. The hub is pressed out, retainer rings removed, then the bearing is pressed out.
New bearing is pressed in, then snap rings, then hub is pressed to spec. I get $45.00 and work for every penny. Michigan cars rust up solid..Good luck. Many times the entire assembly must be replaced if run for too long with bearing noise..
