Remove rhe entire assembly. Take it to a qualified machine shop. The hub is pressed out, retainer rings removed, then the bearing is pressed out.
New bearing is pressed in, then snap rings, then hub is pressed to spec. I get $45.00 and work for every penny. Michigan cars rust up solid..Good luck. Many times the entire assembly must be replaced if run for too long with bearing noise.. |
Add to Bobs post is get a quality name brand bearing like a National or a Timkin or you will be doing it again soon. I am in Ma, also a rust area and I have done some that I thought the press was going to break before the bearing released.
$45 is a steal to press one out and in. We have done a few carry ins and we get $75
Artificial Intelligence is no match for Natural Stupidity Chet |
| Replace none abs wheel bearing with abs bearing | jrmz28 | Hotrodding Basics | 5 | 04-22-2011 07:14 PM |
| 1997 ford f150 removing backing plate, do i need to take the axel out first? | boneyard Buick | Transmission - Rearend | 1 | 12-05-2006 11:01 AM |
| Need help finding steering wheel instalation kit for 93 saturn | goth_rod87 | Interior | 3 | 09-28-2005 09:02 PM |
| wheel hop... 1997 F250 | Trav | Suspension - Brakes - Steering | 3 | 02-11-2004 07:38 PM |
| wheel bearing? | APACHEMAN | Suspension - Brakes - Steering | 1 | 02-09-2004 12:29 PM |
