Removing wheel from blower motor - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-07-2009, 02:30 AM
Absolute beginner
Hi guys,
The car is 78' Monte Carlo.
I need to clean and get blower motor moving. So I need to remove the wheel from it.
I removed the nut from the motor axle. Is there anything else that holds the wheel or I just have to pull it up?
Thanks for the help,
Ivo
Old 09-07-2009, 08:44 AM
The wheel should just pull off once the nut has been removed.
Another problem I had on my '75 was that in that year they used different motors for AC and non-AC vehicles. The motor shaft was a slightly different length, so I had to make sure I got the right one, or it would not fit back into the housing.
Bruce
Old 09-07-2009, 12:32 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
If it don't come right as it should spray it with PB blaster then it will come off. Cole
Old 09-08-2009, 10:32 AM
Absolute beginner
Hi guys,
Thanks for replays.
Please see the picture and let me know, is this metal insert (round and flat one) part of the plastic wheel or it is part of the axle?
It does not move at all and did not come off yet
Hey Cole, what is "PB blaster"? I am not native English speaker and also I am form Bulgaria, so I don't know if it is either some brand or term.
Thanks for your help,
Ivo
Old 09-08-2009, 11:50 AM
Last journal entry: Bringing home the 401 Nailhead
Ivo
PB Blaster is a spray penetrate much like Liquid Wrench and others.
http://blasterchemical.com/display.cfm?p=50003&pid=4
Old 09-08-2009, 12:42 PM
Absolute beginner
Thanks heyjude076,
It is not available here. I use WD40 or some other brand penetrating oil.
In this case nothing yet has helped
Old 09-08-2009, 04:13 PM
eloc431962's Avatar
Wiki Edits: 37
Hey Ivo, Just soak it down and let it set overnight if you can and the W-D40 should loosen it up . Cole
Old 09-08-2009, 05:23 PM
T-bucket23's Avatar
Wiki Edits: 26
Usually a fer light taps on the end of the shaft with a plastic or brass hammer will get it moving.
Patience it the key as those plastic fans break rather easily.
Chet
Old 09-08-2009, 05:24 PM
T-bucket23's Avatar
Wiki Edits: 26
If you have any penetrating oil it will help. WD-40 is not a good penetrating oil at all
Chet
Old 09-09-2009, 01:47 AM
Absolute beginner
Thanks guys,
I will try it and report back to you
Old 09-09-2009, 08:12 PM
eloc431962's Avatar
Wiki Edits: 37
I agree, But it's better than nothing i guess, I like PB Blaster best if he could find some where he is at. I figured soak it with what you have or can get and tap it like T-bucket said. . Cole
Old 09-10-2009, 12:38 PM
Absolute beginner
Hi guys,
Finally it is out... I needed to blow it with hot air gun to remove it. I was very rusty inside the plastic wheel.
Thanks for the help.
Ivo
Old 09-10-2009, 03:07 PM
That stuff is great. It makes WD-40 look like Windex
Rack - it's a type of spray. That's what it's called. I'm not sure if you can get that over there, but if you can, make sure you grab some!
Old 09-10-2009, 03:47 PM
eloc431962's Avatar
Wiki Edits: 37
Hi guys,
Ivo
Glad you got it Ivo. ,,,,,,,,,,,,,,,,,,,,,Cole
Old 09-10-2009, 09:57 PM
I used top be a PB Blaster fan,until I used some KROIL
Shane
blower motor amps jharrison23 Electrical 2 10-24-2008 08:29 AM
7.9:1 or 8.7:1 compression for blower motor on E85? darkostoj Engine 1 10-13-2008 02:47 AM
a/c blower motor diggerthree Introduce Yourself 1 05-30-2007 11:30 AM
Starting your blower motor? How do you? DUKEOFBLUZ Engine 4 05-07-2007 11:44 AM
Early Ford Wire Wheel Tech wheelkid General Rodding Tech 1 06-02-2006 12:15 AM
