removing wheel wells! - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2011, 05:43 PM
cudablack2004's Avatar
have a 90 caprice and wanna lower it alot more but wheel wells is an issue so i came to a conclusion to remove them! The driver side is clear besides the charcoal canister deleted the washer bottle and cruise control object...my concern is the passenger side cuz i have the battery coolant jug and a few electrical items...i need some advice on what to do and keep the battery in its original place?
Old 06-21-2011, 12:47 AM
techinspector1's Avatar
Wiki Edits: 326
Have you considered using smaller diameter tires?
Old 06-21-2011, 07:32 PM
i removed them today wasnt all that bad more space and looks 100 times better! I might get some sheet metal and weld some custom tubs so the water doesnt splash everywhere i was suprised i didnt have to relocate the battery but i do have to mount the coolant jug elsewhere
Old 06-23-2011, 01:39 AM
Wiki Edits: 326
Persistence pays off.
Old 06-23-2011, 10:40 AM
yeah i did the passanger side today and mounted the charcoal canister right behind the headlamp luckily it was 2 holes i could bolt the tabs to! Now i have to remove the wheels and under coat the frame and control arms! Now im in the process of tucking as much wires and hoses as possible for a much cleaner look!
Fiberglass wheel wells amost done. americanLT1 Body - Exterior 7 04-14-2008 08:56 AM
fabricating fiberglass wheel wells. americanLT1 Body - Exterior 1 03-26-2008 11:39 AM
Lowering suspension - but don't want to rub wheel wells Italy's Finest Suspension - Brakes - Steering 7 07-20-2007 05:14 PM
Help with wheel wells? workingclass Body - Exterior 29 02-14-2006 11:20 AM
Cuting wheel wells Chucks,57 Body - Exterior 2 05-08-2003 03:36 PM
