Removing windshield? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2004, 02:05 PM
Hello, I got a amigo and I cant seem to get the windshield out cause the thing is glued in place. Is there anything to disolve the sealant? Under the windshield of my amigo on the drivers side is leaking badly and is rusted out so I need to pull the windshield off.
Thanks.
Old 03-28-2004, 02:13 PM
milo's Avatar
point on positive
There is a tool called a window knife that has a short cable with a handle that you pull while guiding the cutter with the other hand. Pro glass guys even have a electric version. It may be in your best interest however to let your local glass guy take it out and come back after you repair to put it back in. Beware though they may or may not gaurentee against breakage.
If you don't mind if it breaks you'll enjoy ths thread...
http://www.hotrodders.com/showthread...threadid=36433
Old 03-28-2004, 02:22 PM
Anyway could I get ya to post a link to a site for some info on this "window knife"? Can't seem to find anything on it
Thanks
Old 03-28-2004, 05:14 PM
milo's Avatar
point on positive
Here ya go
http://www.med-worldwide.com/product2209.html
Old 03-28-2004, 05:30 PM
poncho62's Avatar
Wiki Edits: 5
A lot cheaper method is to run a piece of piano wire through the sealer from the outside to the inside and run it back and forth around the window. That will losen it enough to pop it out.
Old 04-01-2004, 11:03 AM
bullheimer's Avatar
NEVER use credit cards!
i dont know how much a piano string costs but i used a bass guitar string and it took like over a minute to go 3 inches so it will take a while and good luck. requires two people
