Removing Wire from Relay Pigtail - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2011, 03:55 PM
I would like to switch the red and black wires on a Bosch relay pigtail so they match some older relays I am using (want black to be ground on all of them).
How do you get the wire loose from the pigtail?
John
Old 10-17-2011, 04:36 PM
EOD Guy's Avatar
Pull the relay and look into the female socket, there should be a recessed area on one side, if not look for a little metal tang....... use a very thin jewlers screwdriver and insert from the relay end and depress the tang and the wire will pull right out. bend the tang up and re-insert into the new location
Old 10-17-2011, 05:16 PM
Got it. Thanks.
EZ wiring GM universal harness Relay A, Ignition Relay, and Ground Location 53'Chieftain Electrical 9 05-03-2011 05:57 PM
red orange stripe wire 84 f150 at solenoid relay area fast68 Electrical 0 05-29-2010 01:00 PM
Need a pigtail connector for this: 66GMC Electrical 11 09-09-2006 06:08 PM
Chevy/GM '55-'63 Stop/Tail Light Pigtail Seon Electrical 14 01-27-2006 09:33 PM
how to wire up a 12 volt/40 amp relay for eletric fans on a toggle switch? Blown72Camaro Electrical 4 10-02-2003 08:24 PM
