Reomving windshield from fiberglass top
I installed my windshield and rear window on my fiberglass top w/ 3M window adhesive and I'd need to remove them to paint. This stuff is nasty and has been on for almost a year and I'm not sure how I'm going to get them out. I'm thinking heating it up w/ a heat lamp and sawing away with a putty knife. Any other ideas?
Brian is correct, the heat will not affect it, in fact the heat will probably damage the fiberglass top before the adhesive lets go. The best bet you have is a piece of flexible piano wire about .030 diameter or so. Insert it through the adhesive so it passes from the outside to the inside then work it back and forth along the periphery of the window.
Vince |
use a piece of wire from your wire welder . but wrap it around a piece of wood or you'll remove a finger. or you can pay a fortune for a piano wire.
The problem w/ the welding wire (which I done before sucessfully) is w/ the fiberglass top, the glass sits in a pocket so to speak so the wire will have to make a 90 degree turn to get it though and I don't think it will work. The cutter that was posted might work, but will need to be super thin. Maybe I'll try to make one.
I had my windshield replaced on my DD last summer and asked the tech what he thought. He said he could PROBABLY get it out w/o cracking it.
Thanks for the insight. |
| windshield | sody's 46 | General Rodding Tech | 1 | 08-17-2009 06:50 PM |
| windshield | price | Body - Exterior | 1 | 11-13-2007 09:39 AM |
| fiberglass to fiberglass scoop | bluebu | Body - Exterior | 62 | 06-23-2005 05:15 PM |
| windshield | dbaud | Hotrodders' Lounge | 5 | 09-23-2004 07:58 PM |
| Can a windshield be cut | BLOWN 1100 | Body - Exterior | 11 | 02-09-2003 11:40 AM |
