Repainting over a spray can paint job - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2013, 08:14 PM
Is the spray paint going to cause a problem with REAL auto paint sticking to a vehicle? I am trading an F150 for a Bronco but the bronco has been painted with spray cans. It looks good in pictures, haven't seen it in person yet. But I was just wondering if id have to get all that old spray paint off if I was to repaint it, or if i could just have it sanded down and painted the way it is.
Old 07-26-2013, 08:23 PM
If that spray paint ever decides to lift, then so does everything on top of it, regardless of how well you sanded it. And if they used spray paint I'm doubting what they have beneath it is of any better quality. In other words, given this, and the fact that spray paint has low durability anyways, I'd think you would be risking a lot to put expensive auto paint + your time over an existing spray can paint job.
The other thing is the UV has probably killed the rattle can paint by now anyways.
Old 07-26-2013, 08:27 PM
The truck is just recently been spray painted. But it sounds to me like i should remove the spray can paint, or have the truck media blasted (like ground up walnut shells).
Old 07-26-2013, 09:22 PM
For what its worth, listen to this very good advice that has been given.
Old 07-26-2013, 09:41 PM
Faith - Respect - Trust
Rattle can spray paint doesn't have a catalyst in it...Hardner...without hardner there is a very good chance that whatever you put over top will wrinkle because automotive paints and primers have aggressive solvents in then to aid in the chemical adhesion process and these aggressive solvents will attack a non catalyzed substrate...if it doesn't wrinkle it is still a very week substrate and putting anything over top is a waste of time and money.
Your best bet is to remove the paint...then you need to figure out if the cost of having the new vehicle repainted is worth the investment.
Hope this helps.
Ray
Repainting due to Paint Peel. E-Coated body. Sand to bare metal? 777funk Body - Exterior 22 07-21-2013 07:55 PM
Cheap-ish Paint Job- Spray can? Torque454 Body - Exterior 11 04-16-2010 04:53 PM
Cost of paint Job - complete do it your self job at home Warrant Body - Exterior 74 07-13-2006 09:31 PM
First paint job -- some dry spray.... pmeisel Body - Exterior 4 07-07-2005 01:10 PM
Spray Can Paint Job LuckyCustoms Body - Exterior 9 05-08-2004 09:55 PM
