Myself I wouldn't trust it myself. Iron Pontiac intakes are not hard to find and in my opinion I would replace it.
Yes it can be welded by a GOOD welder but that can be pricey. See what your machine shop says for a price to fix it *** correctly ***. I just looked on Ebay...there are a bunch of intakes on there that would fit your application, cast and alum..
Chunk it and get a aluminum intake. Few people can properly weld cast iron. The only time I would bother to have it done was if I was dealing with a rare piece in a restored vehicle such as a 1969 chevy 302 block for example.
Cast iron can be easily brazed, if you have a oxy/acetylene outfit at home you can do it yourself as long as you preheat it...barbeque works fine. It really depends on if the crack is accessible or not and how much it is worth to you...a machine shop would likely charge $50-$100 depending on where and how bad the crack is.
New intakes are cheap.
Outlawed tunes from outlawed pipes |
I had to have my 400 block repaired, outside starter bolt hole had busted out and some goober had welded it up solid,didn't notice till I had already had it to the machine shop.Took close to 2 hours to weld up,with the cooling time,$50 at a local welding shop.
I have done a little cast welding,when I was in HS,and did not find it that hard,with proper preheat,post heat and cooling,It is no more difficult than welding mild steel, Its the prep work that makes it tedious and time consuming IMO. Shane |
A number of years later I realized what I had lost .Vince |
I talked to the shop today and they told me the intake manifold is usable as is but if the vertical divider crack spreads to the horizontal divider then a vacuum leak occurs. Cost to plug it is $100. I am not sure what plugging is?
I was wrong on the other crack location. It's on the outside barrel casting and does not go through to the inside. The shop didn't seem too concerned about this crack and told me to JB Weld it from the outside. Since I have a second Pontiac factory intake I will use the second one. BT Houston, TX |
plugging
Plugging is a method that uses a series of overlapping drilled holes, taper tap and taper plug one set at a time to repair cracks. I haven't seen it used for the last 50 years.
| Leak on top of SBC 350 intake manifold | 75gmck25 | Engine | 9 | 01-23-2009 09:11 AM |
| leaking intake manifold | poisonknives | Hotrodding Basics | 16 | 01-06-2009 06:51 PM |
| What bolts for intake manifold | sabino56 | Engine | 4 | 08-01-2006 06:45 PM |
| Welding Cast Iron | OneMoreTime | General Rodding Tech | 3 | 01-22-2005 05:46 AM |
| Need some intake manifold help | killerformula | Engine | 14 | 11-29-2003 10:07 PM |
