Repair and Paint within body lines - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-02-2010, 02:24 AM
milo's Avatar
point on positive
Heres what happens when parts are put together to soon..
In Italy they have wine during lunch even at the factory,
Here we have factory waterborne paint sliding and a wrinkleing
check the mileage
ID:	49466   Click image for larger version
ID:	49467   Click image for larger version
ID:	49468   Click image for larger version
ID:	49469   Click image for larger version
Last edited by OneMoreTime; 01-08-2011 at 03:27 PM. Reason: Violation of guidelines. Please see: general board guidelines.
Old 11-02-2010, 03:12 AM
jon72vega's Avatar
WOW, I could have had a V8!
It looks like a bird used the speedometer for bombing target practice!
Jon
http://1972vega.wordpress.com/
Old 11-02-2010, 03:13 AM
milo's Avatar
point on positive
Halloween OR San Francisco Giants Orange seems appropriate enough this week
Now to find some body lines to blend to since the rest of the paint is in spanking new.
The good news is the waterborne bases are availabe in the formula already..
Gonna blend up to the close line on both sides
Posting projects gets them done..
ID:	49471   Click image for larger version
ID:	49472   Click image for larger version
ID:	49473   Click image for larger version
ID:	49474   Click image for larger version
Old 11-02-2010, 03:33 AM
milo's Avatar
point on positive
Jon
yep, it has been on a back lot..they can't put it on the sales floor....yet .. I like your sig link, works for me too
Heres a link to an old thread with solvent type faster bases and non compliant clear from days gone by that shows some of what this one is in for.
Wait err, there's a fly in my paint..
If you like tight fixes your in the right place.
Old 11-02-2010, 08:45 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
H'mmmm I wonder if the rest of the car was built that way..??
Sam
Old 11-05-2010, 05:24 PM
Old Fool's Avatar
Sam
I doubt it, I think it is a motorscooter.
Old 11-06-2010, 03:27 AM
milo's Avatar
point on positive
First to set some healthy boundaries.
The masking tape makes it around the crown line to keep repairs within the "shoulder" remember we need that bodyline to hide the blend..
ID:	49642   Click image for larger version
ID:	49643   Click image for larger version
ID:	49644   Click image for larger version
ID:	49645   Click image for larger version
Old 11-06-2010, 03:34 AM
milo's Avatar
point on positive
not to ask primer to fill, a 2 part glazing compound levels the field of play..
ID:	49647   Click image for larger version
ID:	49648   Click image for larger version
ID:	49649   Click image for larger version
ID:	49650   Click image for larger version
Old 11-06-2010, 03:41 AM
milo's Avatar
point on positive
After bodywork, the tape is removed and any stray putty flecks off the unsanded paint with a fingernail edge. Then retape and cover everything except where it's ok for primer to be.
ID:	49652   Click image for larger version
ID:	49653   Click image for larger version
ID:	49654   Click image for larger version
ID:	49655   Click image for larger version
Old 11-06-2010, 11:11 PM
milo's Avatar
point on positive
Heres the piece now in primer with a guide coat after sitting for 18 hours.
The next prep step is to sand the hard primer line near where the tape was as well as the rest of the area to be paint/blended but first to put another piece of tape this time allowing just past the primer edge to show to protect that bodyline.
ID:	49743   Click image for larger version
ID:	49744   Click image for larger version
ID:	49745   Click image for larger version
ID:	49746   Click image for larger version
Old 11-09-2010, 07:56 AM
milo's Avatar
point on positive
Here is the piece with the primer sand protection tape removed.
To prep the blend corner it is cleaned with windex on a 3M ultra fine scuff pad followed with a few light brushes with 1000 grit dry to give it just enough tooth for the clear.
Finally 3M door aperture tape is placed along the crown of the body line...
ID:	49834   Click image for larger version
ID:	49835   Click image for larger version
ID:	49836   Click image for larger version
ID:	49837   Click image for larger version
Old 11-09-2010, 08:38 AM
milo's Avatar
point on positive
The base color is "dusted" on shooting down across the foam tape at an angle as not to flood into the crevice created by the rounded foam tape. Not to rush especially with waterborne, give it 20 minutes between light coats until it's covered.
When it is clear time cast a light drop coat wait one minute and then slam a single wet coat straight on towards the foam tape so it will swirl in there complete.
ID:	49839   Click image for larger version
ID:	49840   Click image for larger version
ID:	49841   Click image for larger version
ID:	49842   Click image for larger version
Old 11-09-2010, 08:48 AM
milo's Avatar
point on positive
...now to take 5 minutes to clean the gun and then remove the foam tape turn on some heat and relax..
ID:	49844   Click image for larger version
ID:	49845   Click image for larger version
Last edited by milo; 11-09-2010 at 08:56 AM. Reason: Envirobase One Visit, done deal ...
Old 11-12-2010, 09:30 AM
milo's Avatar
point on positive
For the front fender. A bit of heat, then pressure , and cold water and the plastic crest "fits" better.
ID:	49977   Click image for larger version
ID:	49978   Click image for larger version
ID:	49979   Click image for larger version
ID:	49980   Click image for larger version
Old 12-14-2010, 08:15 PM
milo's Avatar
point on positive
One blend project always leads to another ..
Here's one that even puts butterflies in my stomach.
I love it when asked to do the scary ones, keeps me at the top of my game
ID:	50836   Click image for larger version
ID:	50837   Click image for larger version
ID:	50838   Click image for larger version
ID:	50839   Click image for larger version
Paint and Body Maintenance and Repair CrimsonSam Body - Exterior 14 08-27-2006 03:59 PM
body lines dboyett38666 Body - Exterior 2 02-19-2006 09:48 AM
who can guid me through body lines? a69446b Body - Exterior 3 11-08-2005 08:40 PM
Lost body lines Rat Race Body - Exterior 7 04-16-2004 06:02 PM
body lines racur96 Body - Exterior 0 12-12-2003 05:30 PM
