Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Repair/replace Vinyl top?
Old 10-24-2002, 07:21 PM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
Post
vinyl top replacement is not for the average joe, you have to use contact type cements and be fast and accurate it takes years of experiance. on the other hand there are lots of vinyl repair kits available at parts stores the best is Mar-Hyde you can glue the tear down, fill imperfections, then clean the top with prep-sol or mild enamel reducer then mask and recolor, if you take your time you can do a pro job that no one can tell in your garage with a rattle can of vinyl dye.
