Repair or restore foam filled armrests that have been spray painted - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-17-2008, 12:50 AM
ret_marine2003's Avatar
Good morning ladies and gents,
I have a strange dilemma.
Someone had cobbled a couple of parts on my bone stock 1950 Studebaker Champion Regal Deluxe in the past.
I have been looking but have not found replacement OEM arm rests anywhere.
My arm rests are all well worn but have been crudely repaired by spraying several coats of silver paint on them.
Is there a repair for this?
If not do you have any experience based suggestions?
Semper Fi,
ret_Marine2003
Old 08-17-2008, 08:56 AM
DanTwoLakes's Avatar
Wiki Edits: 22
What exactly is left of the armrests? Is the silver paint on the foam from the armrests or is there still fabric over the top of the foam? Would it be possible to post a picture?
Old 08-18-2008, 10:52 AM
Good afternoon Dan.
There is old cracked vinyl covering the arm rests under the paint.
Whoever painted the armrests had taken the armrests off first, painted them; and then reinstalled them. The door panels do not have any paint on them.
The paint is old and thick.
I do not think it would be possible to remove the paint and keep the vinyl material under the arm rest in tact.
I am waiting on new CD-RW disks before I can post pictures.
(Sony Mavicam camera is all I have and was outdated as soon as I purchased it. It works good, so I keep it despite the annoyance with the disks.)
I suppose in hindsight this is typical damage.
At some point a child of the sixties probably owned this car and came up with the silver arm rest idea when the car was painted black over the original blue-green color.
Old 08-18-2008, 12:27 PM
Wiki Edits: 22
You are in luck if the original vinyl is still on the armrests. Your armrests should come apart somehow, and once you have the armrest apart, you can take the old vinyl off and replace it. I can give you a better answer if you can post some pictures.
arm rest foam repair esahlin Interior 3 08-07-2008 02:36 PM
low priced spray gun/detail gun for primer/base/clear and ghost flames jrmy_1 Body - Exterior 15 06-08-2008 06:38 AM
