repair time/2013 roof skin - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-27-2013, 09:28 AM
deadbodyman's Avatar
Wiki Edits: 11
Due to hail damage I have 10 2013 Nisson frontiers 4 dr ext cab,that will need roof skins these trucks have 10-20 miles on them (brand new) What I need to know is what is the repair time to R&I and if they are welded or glued on.. any help at all will be greatly appreacated.....
Old 06-27-2013, 09:42 AM
put up or shut up
that's a huge job. I'm guessing at least a 26 hr job. I just did a huge van uniside, sort of the same size as your roof that calls for the same R&I other than that you have it harder cause you have to completely remove the head liner, and it's not just huge plastic inner side panels like I faced. That tear down will be lots of more work than I faced. Gonna glue it in? Weld? or both? I'm guessing a 32 hr job but better to ask Martin, he's an estimator and can look it up on Mitchell.
Old 06-27-2013, 09:50 AM
Wiki Edits: 11
Brian ,Of coarse ,why didnt I think of that....
I never get the EZ stuff...
Old 06-27-2013, 10:00 AM
put up or shut up
you're not the only one. I do all the train wrecks around here too.
Old 06-27-2013, 10:23 AM
The roof time on the regular cab is 18.5 plus .8 for each side air bag. I don't know why that's not included being they all have side air bags, oh well. The 18.5 does include to R&I all the headliner, trim, and windows.
If it's a crew cab, it's 22.2 with sunroof and side rails, 21.6 with sunroof without side rails.
Without a sunroof and with side rails it's 21.0 without sunroof and without side rails it's 20.4
But realistically you need to paint both side roof rails and blend both cab corners (1.6 and 1.0 each) so that means the bed comes off (2.5)
I would likely find a bunch more little things like the vents on the back of the cab if it has them and a zillion other .2 little goodies that add up.
But there you go.
Old 06-27-2013, 10:26 AM
And remember, that is "R&R" time, "Remove and Replace" Not "R&I" which is "Remove and Install" as in the bed, the bed is "R&I", as is the head liner, and anything that the original part is reinstalled.
Old 06-27-2013, 11:21 AM
Banned
sadly most dealers would spot fill, then slick sand and paint,
howed the hail miss the hoods top of fenders and bed side tops
Old 06-27-2013, 05:42 PM
Wiki Edits: 11
the hail didnt miss anything but I already know what it takes to replace a hood and all the bodywork 23 hrs plus 20hrs for the roof ...so were looking at about 40 hrs altogether....thanks guys I really hate guessing because I guessed 10 hrs
Old 06-27-2013, 05:44 PM
Wiki Edits: 11
Thanks for pointing that out Brain.
Old 06-27-2013, 05:48 PM
Wiki Edits: 11
Its black too...which isnt such a big deal but I'll have to wear my welding helmet if I want all that orange peel
Old 06-27-2013, 10:10 PM
I don't get...
Old 06-28-2013, 06:42 AM
Wiki Edits: 11
The robots at the Nisson factory dont paint so well
Old 06-28-2013, 09:01 AM
put up or shut up
good thing it's not metallic, cause then you'd have to tape your gun to the end of a broom stick and make jerky robotic passes.
New video up...restoring instument gauge/ bug from hell / roof skin tech69 Body - Exterior 14 09-26-2011 10:12 AM
roof skin is off!! dual4 Body - Exterior 8 06-11-2010 09:21 AM
replacing a roof skin on a 69 dodge dart glhx Body - Exterior 49 09-01-2008 04:37 AM
How critical is the roof skin on a unibody car? beemdubya Body - Exterior 19 08-04-2006 09:26 AM
Body time! Give me some skin Madd Syntst Body - Exterior 6 10-31-2003 01:03 PM
