Repairing Cracked Weld on Radiator - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-23-2005, 04:44 PM
The problem with taking a chance on a "bandage type repair" is that you never know when or where it will fail and the problems caused by failure in this case can run from a minor inconvenience to maybe getting stranded somewhere or worse, a cracked head or block.
On a lighter side, about ten years ago at a mine in Kentucky I had a flat tire on my truck with no way to change it. It was about midnight and well below freezing and all I could find in my tool box was a very coarse thread lag bolt and some silicone sealer(blue glue) so I ground the head of the bolt down thin so it would not stick out so far, squeezed some sealer on it and screwed it into the hole in the tire. I thought if it would hold air long enough for me to make it out to the highway I would be a lot better off stranded by the road than on top of that frozen mountain but the darn thing made it from near Ashland Ky to just north of Knoxville Tn. a distance of nearly 250 miles and was still holding air when I went to the tire shop the next day! Amazing what one can sometimes getaway with when the chips are down
  #17 (permalink)
Old 12-23-2005, 06:21 PM
Well, I added a bottle of Bar's Leak to the radiator and then let it run for 20 minutes per the directions. As it got hot it dribbled a little, momentarily shot a whisker thin stream, reduced to a slow dribble and eventually dried up.
Haven't driven anywhere yet, so it is still wait and see.
We will only be driving locally till next spring, so springing a slow leak shouldn't strand us if it returns.
Thanks for all the replies.
John
  #18 (permalink)
Old 12-28-2005, 07:06 PM
Sounds like you've got it taken care of. I've used Aluma-Seal many times for a small seam crack. Don't forget to have it taken care of properly as soon as possible.
BTW...I've also used the pepper trick as well as powdered ginger. Both were used when I was a broke kid in the early 70's and stopped up the radiators just fine. Would not recommend with today's higher pressure systems though.
  #19 (permalink)
Old 12-28-2005, 10:07 PM
rustawaydav
this is a reply to a cracked radiator tank. I own a radiator shop. The tank can be repaired ,by a competent radiator repair man, using silver solder. Thanks
  #20 (permalink)
Old 12-29-2005, 08:22 AM
David Enders's Avatar
custom rad
Looks like you've decided to bite the bullet and fix it right. Might take a look at a aluminum one. Try Ron Davis radiators in Phoenix Az. area, I've checked out their wed site and it looks like they can fix you up. I'm cure it wont be cheap but it will be right. Good luck.
  #21 (permalink)
Old 02-11-2009, 11:26 PM
V8 Biker
Just did the same tick
John
Had a slow leak at the bottom of the aluminum radiator from the lower left mount area. So added a vial of the silver Barrs Leak powder that treats up to 3 gallons (mine holds 2.5 gallons) and leak seams to have dried up. This is on a 2004 Boss Hoss 350 bike with 55,000 miles..with electric Water pump. I think the leak stemmed from the bracket beating up againts the tank...must have loosened the plastic/rubber mount isolator, so it was metal beating up againts metal every time I hit a front end bump.
http://community.webshots.com/photo/...03803557zjtDlr
Cheers
Aldo
  #22 (permalink)
Old 02-12-2009, 06:10 AM
Hoss, since that post was back in 2005 I would think that he has that leak fixed by now.
  #23 (permalink)
Old 02-12-2009, 08:09 PM
V8 Biker
Yep I figured that...
Yep I figured that...I posted it just in case someone wanted to offer a better or newer fix.
Cheers
Aldo
  #24 (permalink)
Old 02-12-2009, 08:22 PM
302 Z28's Avatar
oops old post
Vince
  #25 (permalink)
Old 02-12-2009, 10:15 PM
Originally Posted by Hosszz4
Yep I figured that...I posted it just in case someone wanted to offer a better or newer fix.CheersAldo
Please don't mis-understand I was not scolding, there is nothing at all wrong with adding good info to an old post I just wanted to make a note of the fact it was old so anyone else who might reply would be aware of it.
  #26 (permalink)
Old 02-12-2009, 11:24 PM
If the epoxy or JB Weld doesn't stop it, as a last resort I'd try drilling the pinhole a little bigger and putting a sheet metal screw and neoprene washer in it. If it's a crack, you could try drilling a small hole at the end of the crack to stop it running any further, and then plug it. Sometimes fixes like that last forever, sometimes not.
  #27 (permalink)
Old 02-12-2009, 11:27 PM
Oh, just read the date on the original post. Goofed again!
  #28 (permalink)
Old 02-13-2009, 06:59 AM
That often happens when someone digs up these old posts and sometimes it can be a bit frustrating if you write up a lengthy reply only to find out the question was from years ago, it has happened to me. That's why I mentioned the date and anyone who does reply to one of these ancient posts should think carefully about whether or not the reply is really something worthwhile and PLEASE when you do point out to everyone it is an old post!
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 10:45 AM
Welding info Kevin45 Body - Exterior 10 08-26-2011 09:09 AM
Question on Mig Welding - HOW to modas Body - Exterior 43 12-31-2005 10:48 PM
Welding Books Magnus_Jager General Rodding Tech 6 11-29-2005 04:57 PM
Cracked weld on strut?? Dave E Shank Suspension - Brakes - Steering 14 02-11-2004 01:20 PM
