Repairing Damaged Threads - 1/2" X 20 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-07-2008, 07:32 AM
72NOVA454
I've got a situation where I have a 1/2" x 20 bolt (wheel stud) where the first 2-3 threads are not cleanly defined in some areas, and the nut is not going on straight. This nut came off clean and easy - not sure how or why the last couple threads got damaged. They look very repairable, there is just a couple of "spots" on the thread that need to get cleaned up, most of the thread around the nut is perfect.
What is the best way to restore/repair those last couple of threads? Should I get a 1/2" x 20 die, or is there some other secret method? A tiny file that fits in between the threads? I've tried a few different nuts and none of them will spin on. I'm just using my fingers on the nut - I know not to force it on or it will make the situation worse.
Lee
Old 10-07-2008, 07:45 AM
Last journal entry: Bringing home the 401 Nailhead
Find a thread file. Here is one supplier:
http://www1.mscdirect.com/CGI/GSDRVS...00000070998603
Sure there are others. Be sure that the file you purchase has a 20TPI profile.
Old 10-07-2008, 08:32 AM
Last wiki edit: Removing stuck fasteners
repairing lug studs
I just change it, it'd be a quick and great repair for almost nothing. Just knock it out and install another by putting it in the hole and then a larger nut over the threaded end and start the nut (also new) and tighten to pull it into the hole. lol
Old 10-07-2008, 08:33 AM
OHD's Avatar
OHD OHD is offline
Are the damaged threads on the outside towards the end of the stud? If so you can attempt to clean them up with a file wire wheel or die.
If they are down next to the wheel, where the nut applies the holding/clamping force, replace the stud.
Old 10-07-2008, 08:44 AM
72NOVA454
wow - I feel like a total ******* now - I never new such a tool existed. I must have 500 tools in my garage and I've never seen a thread file. I attached a photo so other dummies like me can see what this tool is and learn from it. I'm sure every machinist and auto mechanic (except me) has one.
I'm buying one today. That will fix my problem - thanks buddy.
For dummies like me that never knew this tool existed - here is what it looks like. The tool has 2 halves. Each half has four different TPI (thread per inch) files. So a total of 8 thread files in 1 tool.
Lee
Old 10-07-2008, 08:48 AM
72NOVA454
sounds like a good idea except......................this is not an OEM stud. It's a 1/2" X 20 by 2-1/2" long. I have to pull the axle out to remove the stud. Not enough clearance behind it to screw it out. It's a threaded axle stud - not the press in type. Hard to explain but you get the idea. Pulling the axle is a pain in the butt as you know, just to repair 1 or 2 threads on 1 stud. I'm going to use a thread file as recommended by another forum member. Take care - and thanks.
Lee
Old 10-07-2008, 08:53 AM
Lee
I have several that cover most TPIs. Suggest you do the same.
Old 10-07-2008, 05:28 PM
4 Jaw Chuck's Avatar
A small tool and die makers triangular file works just as well as a thread file, you probably already have one in your tool box. Easier to get into tight spaces too.
Repairing a damaged crank by welding.. Old School Nut Engine 7 05-10-2006 09:05 AM
