Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - repairing fiberglass hood
Old 11-24-2010, 04:47 PM
Chris Kemp Chris Kemp is offline
Fiber glass is great and if used like Brian has stated you will not have a problem. But just like he said, you have to thin down the damaged areas and that means the hairline cracks also. If there was cracks in the paint then the hood is cracked there too. The only way to repair it so it will not come back is to thin down the cracked areas and then fill in those thinned down areas with a repair material. I have had great success using a product called MarineTex. It is a marine epoxy that has been around along time. I have used it from start to finish on the same type of repair that you are doing. It will not shrink or show ghost lines down the road after the sun has baked on it for a while. Not to put down Brian's method because it will work great but IMO MarineTex works on smc better then regular fiber glass.
