Hi guys,
To fit my T56 into my 84 Jaguar XJ6, i had to cut some of the transmission tunnel out. I cut a bit extra, so that it'd be easier to install. Now I have hot air rising from under the car, and making it's way into the cabin. Is there a trick, or some kind of specialty rubber material used to patch these holes? I need a regular shifter boot still, but this would be the barrier between the underside of the car and the trans tunnel itself.
Any help would be appreciated!
Tyler
Tyler
