repare plastic fuel tank?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-08-2006, 08:14 AM
great adventure's Avatar
dear members..
I've got strange question about repairing plastic fuel tank..
if i am not mistaken most of the American cars switched to
plastic tank instead of steel one..
and my opinion I only recommend the above tank for boats
only to avoid heavy weight and rust??
in case if this tank get cracked if hole how you will repair it??
I have used all types of sticking material like epoxy, jb weld
fiber glass etc but still leaking... and advise please
ga
Old 03-08-2006, 08:23 AM
Napa used to sell this stuff, 2 part, designed for just such an occasion. Never used it personally, however, sold a bunch of it & never heard anyone ***** about it not working.
Old 03-08-2006, 10:38 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
clean well and fix it with a 2 part epoxy. worked for me
Old 03-08-2006, 01:13 PM
thank you so much will try to make the area ruff and then apply
the 2 part epoxy
ga
Old 03-08-2006, 02:32 PM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
rought it up with aome 100 grit sand paper, then clean with mineral spirits or paint thinner. Gasoline leaves a residue that the eopxy won't stick to. If you use a plastic tank repair kit, make sure the adhesive is good for polyethylene (sp?). That's what most are made of. Some glues won't work with it, others will. The epoxy should work once cleaned and roughed up though.
Fuel Tank for 50 Chevy P/U DirtDoctor Hotrodding Basics 8 01-14-2006 07:43 AM
50 chevy pu fuel tank options fat50chevy General Rodding Tech 4 09-03-2005 03:35 PM
Need help on dual fuel tank wiring on 86 chevy truck shockers69 Electrical 2 12-26-2003 11:09 PM
56 Chevy fuel tank removal Dawger General Rodding Tech 0 11-15-2003 03:50 PM
350 chevy not getting fuel from tank ?? GREENTHING Engine 10 07-22-2003 09:18 PM
