reparing a drip rail - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2009, 04:53 PM
I have a drip rail from a camaro it has several scratches but is not dented or bent at all. I think it is aluminum or stainless can i sand the peice then polish it or will that just make it worse. I tried doing some research on it and it seems you can sand aluminum? Can anyone tell me what grit of sandpaper to start with? Thanks to anyone that may be familiar with doing this.
Old 08-18-2009, 05:11 PM
shine's Avatar
SPI Thug
Last journal entry: some progress
i restore ss . i sand to 1000 wet then polish. you cant cut ss much by buffing . one important thing is to tape the piece to a buck so you dont bend it while buffing.
Old 08-18-2009, 05:20 PM
Thank you, when you use the buffer do you use the same type of polish as for the body of a car such as meguires polish. thanks
Old 08-18-2009, 05:35 PM
shine's Avatar
SPI Thug
i use a bench grinder style buffer and ss polish . eastwood is as good as anywhere to get it . just be careful. i wear welding gloves and safety glasses. ss trim is like a razor blade. i saw a guy loose a finger polishing trim. wheel caught it and cut right through his glove. that is why i have wooden bucks for all my trim work. dowel rod or 1x1 pine .
Old 08-18-2009, 07:54 PM
deadbodyman's Avatar
Wiki Edits: 11
good tip shine
Installing Stainless Steal Drip Rail Trim 65comet Body - Exterior 0 10-28-2008 08:52 PM
Drip Rail w/ new quarter crusherdbuzz Body - Exterior 1 06-13-2008 10:08 PM
Drip Rail Delete SHIFTY101EASY Body - Exterior 27 01-30-2007 03:24 AM
Drip rail help 46 chevy pickup Body - Exterior 2 06-12-2006 05:12 AM
Drip Rail repair help Overdrive39 Body - Exterior 3 05-04-2005 03:10 PM
