Repeat of lost thread, what front suspension is this? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2005, 09:56 PM
Last journal entry: Some pics
The following is the front end in a 59 ford truck. However it is not original, so I am trying to figure out what front end it is. It is probably out of a gm. At least the steering column is a gm. So I figure it is some sort of gm product. How do I tell if they put it in there right. Lots of stuff is done kind of half assed on this truck, but if the front end is in there ok it may be worth working with.
ID:	4190   Click image for larger version
Old 03-11-2005, 01:21 AM
redlightning's Avatar
If someone here doesn,t have a answer.You might try www.ford-trucks.com and go to forums and then find your year.They do a lot of engine,trans,and suspension swaps.
Old 03-11-2005, 04:49 AM
3rdmember
looks like about a 70-81 camaro/fbird that somebody REALLY F'd up.
either start over or make DAMN sure it's in there straight AND at the correct angle.
Old 03-11-2005, 07:16 AM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
looks like a 80's GM front suspension w/a Metric steering box. most likely from like a midsize GM car like Monte Carlo's and alike cars..joe
Old 03-11-2005, 10:08 AM
johnsongrass1's Avatar
Race it, Don't rice it!
53" from horn to horn on the metric stuff. 56" on the SAE stuff.
That looks nothing like a metric or SAE frame horns.
Old 03-12-2005, 07:18 AM
Looks like a "Halloween" suspension. It screams "Trick or Treat" and strong on the "Trick" side. Otherwords, scares the heck out of me!! I would not trust it sitting on a trailer, much less driving it.
Trees
Front suspension on 1938 International 1/2 ton truck Googles Pisano Suspension - Brakes - Steering 5 08-10-2010 01:20 PM
Front Suspension camaro1127 Suspension - Brakes - Steering 4 03-11-2005 10:09 AM
32 hi boy chrome front suspension McDeuce Suspension - Brakes - Steering 3 12-08-2003 06:52 AM
vw bug front suspension Blob Suspension - Brakes - Steering 5 11-09-2003 06:17 PM
