Clarify Please??
Could you explain further to a DUMMY!
Dou you mean to physically go inside the steering box and turn around some type of worm gear or something, or just by changing WHERE the box is mounted; the direction will be changed?????? I know that if you know anything about steering box insides, I should be able to figure out what you mean, but the only one I've ever seen the inside of is a 30 model and it had the steering shaft gear, and a worm gear on the output shaft [or something like that] and that was all]; no other gears. NOTE: JUNK YARD SAYS 85-94 ASTRO VAN STEERING BOXES ARE INTERCHANGABLE; EXCEPT THERE WAS A 'SPORT BOX MADE FOR A FEW YEARS" WHICH PROBABLY JUST HAD A DIFFERENT RATIO.
Hi i sent my box to a fellow who rebuilds power steering boxes for a living he did the work for me so I dont know exactly what he did but from what I gatherd he reversed the gears. So maybe if you contact a rebuild place they can tell you. Or if you want I will give you the # of the place I got it done at and they will exsplane to you what they did.
I will contact a rebuild shop, after I open mine up and look inside [got to look and see if I can figure it out myself first
], then I'll have a pro look at it, That's the old budget thing again .Thanks for confirming I had to go INSIDE. Don |
