Replace Ignition Key Lock Tumbler - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-11-2008, 07:13 PM
How do I replace the Ignition Key Lock Tumbler in my 1972 Camaro.
Old 11-11-2008, 08:25 PM
As I recall, you have to remove the wheel and the turn signal switch, then depress a tab in a slot next to the switch inside the column (lock in the RUN position) to get the lock cylinder out... at least that works on later 70's models.
Old 11-11-2008, 09:27 PM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
Or, if it is stuck, very carefully drill it out. I had a car ('73 Buick Century) that I had to do that with. At work one night. In a blizzard. I despise key/lock issues more than chasing electrical gremlins...
In a while, Chet.
Old 11-11-2008, 10:15 PM
This web page shows GM column disassembly for tightening a loose tilt column, but the steps up to ignition lock removal are the same for all 69-up GM columns.
http://buickperformance.com/tiltstee...lumnwobble.htm
Old 11-12-2008, 06:21 AM
You will do quite a bit of disassembly to get to the release, and then the lock cylinder simply slides out.
The only hard part is the lock plate remove/reinstall, and that is not bad if you buy, borrow or make a removal tool. I didn't want to make a run to the store, so I made a tool from a flat piece of metal stock and three bolts. Its not pretty, but it works okay.
Bruce
setting points on sb chevy frackster66 Electrical 23 01-07-2014 06:50 PM
Loose Gm Tilt Steering Wheel Moves Up And Down fumplet Suspension - Brakes - Steering 10 05-13-2012 07:07 PM
Removing Ignition tumbler with no keys flyinv55 Hotrodding Basics 3 09-14-2008 01:24 AM
Camaro VATS ignition and column RockinLocks4u Electrical 9 02-03-2005 10:34 PM
steering column ignition broke zonk Suspension - Brakes - Steering 2 03-24-2003 02:33 AM
