replace ignition switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2011, 12:27 PM
mnwilliams2010's Avatar
1985 ford f150 5.0 efi automatic,cruise control,tilt steering wheel.
I lost the key to my ignition switch & want to replace it.
How do I do this?
Someone said there is a small hole on the steering column to help remove it,but,there is no small hole anywhere on the steering column.
please help,& thanks for any help.
Neil
Old 06-13-2011, 02:10 PM
How do I do this?
Neil
That pin release hole won't do you any good without the key, it makes clanging the key tumbler easy IF you have the old key inserted but without it you are out of luck.
Old 06-13-2011, 02:51 PM
That was supposed to be "changing" not clanging.
Old 06-14-2011, 12:36 PM
pin hole for ignition switch
Like I said in my post there is NO pin hole anywhere on the steering column unless it is under the switch,but not on the outside of the steering wheel.
thanks
Old 06-14-2011, 04:26 PM
T-bucket23's Avatar
Wiki Edits: 26
thanks
you would need to remove the wheel and possibly the turn signal switch to access the release hole. It wont do you any good if you dont have the key. A fairly simple solution, if the door key was the same as the ignition key, is to pull a door lock and take it to the lock smith and they can make a key. If this is not the case you could carefully drill the old cylinder out or pull it with a dent puller type slide hammer. This usually will not damage the column and a new cylinder can be inserted
Chet
Old 06-14-2011, 07:27 PM
Would it cost about the same to have a lock smith come out & make a key?
thanks again.
Old 06-14-2011, 08:14 PM
thanks again.
Only your locksmith knows.
Most likely the door lock is keyed the same as the ignition and if so they are easy to remove, hardest part is removing the door panel but they aren't all that hard to remove. Taking that lock to the Smith would most likely be cheaper than having them come out, call and ask and if it is going to cost a lot extra for the service call then removing the door lock may be a viable option.
Old 06-15-2011, 05:56 AM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
It's an 85 Ford.
A good locksmith can come out and make a key from a blank without even opening the door. Might take him all of 15 minutes.
(Can't do this with a GM lock)
But---removing the door lock cylinder yourself and taking it to the guy would be a lot less spendy.
How Do I Remove And Replace Ignition Lock Cylinder JNCM1932@YAHOO.COM Hotrodding Basics 10 06-14-2011 09:48 AM
Replace Ignition Key Lock Tumbler raglandk General Rodding Tech 4 11-12-2008 05:21 AM
toggle switch / ignition switch help help! 39chevy Electrical 4 08-18-2006 06:04 PM
How to replace ingnition switch? hcker2000 Electrical 20 05-17-2004 06:36 PM
Ignition switch! Trav Electrical 8 11-23-2003 12:27 PM
