Replace none abs wheel bearing with abs bearing - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-20-2011, 07:33 PM
Hey I have a 2004 Buick century non abs the question is can I use a abs style bearing ? They are cheaper I don't know why . Thanks John
Old 04-21-2011, 01:50 PM
As long as all dimensions are the same, no problem. I've seen many instances where they would interchange.
Old 04-21-2011, 02:19 PM
Typically the difference is the ABS one has a "tone ring" on it. It's a gear looking thing that spins with the hub and is read by the ABS sensor. The knuckle often even has a little boss where the ABS sensor would go that is simply not machined to accept it so the bearing should work.
I have to tell you on this particular subject on many cars that "tone ring" is not a gear looking thing at all but is a magnet in the bearing that you can't even see! The difference between the tone ring side and the other side could be something as minor as a simple unpolished surface. The bearing will go in either way but in backwards and your ABS sensor won't work thus, the ABS light will be lit on your dash because the system doesn't work.
Ask me how I know. We had it happen to a couple of cars. The last one the mechanic swore it was in ok so we replaced the sensor, nope, sorry dude, we ended up replacing the bearing and putting it in properly.
Old 04-22-2011, 06:51 PM
dklong's Avatar
yes they will work ! I've seen a lot of cars come into our shop with factory abs bearings and the cars has no abs !
for some reason the non abs bearing are more expensive, they should be cheaper , because they have less parts on them
Old 04-22-2011, 06:58 PM
LATECH's Avatar
its cheaper to manufacture one style and wharehouse it than to keep track of two styles and wharehouse them both. One size fits all.
The car may or may not have the electronics, that is where the rubber meets
the road...litterally.Pun intended LOL
Old 04-22-2011, 07:14 PM
BOBCRMAN@aol.com's Avatar
The bearings I get from NAPA are coded with a red seal on the ABS side and a plain black seal on the other side.
Wheel bearing.... SouthernRodder Suspension - Brakes - Steering 1 12-30-2007 08:14 AM
75 Vette wheel bearing! SouthernRodder Suspension - Brakes - Steering 4 05-05-2006 02:12 PM
Replace old bearing races or keep them??? 406chevelle Suspension - Brakes - Steering 7 05-20-2004 02:17 PM
tiny little fish-scale-like flakes of bearing on bearing/journal bullheimer Engine 2 04-16-2004 01:12 PM
wheel bearing? APACHEMAN Suspension - Brakes - Steering 1 02-09-2004 12:29 PM
