Replace old bearing races or keep them??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-17-2004, 08:58 PM
406chevelle's Avatar
One of these days...soon
Wow I havenít been on in awhile, I sure miss this place.
I am putting new wheel bearings in the front of my 72 Chevelle and I donít think I will be able to remove the old bearing races, would it be ok to leave the old races in and just install new bearings???
The races seem to be smooth as glass.
Thanks,
406chevelle
Old 05-17-2004, 09:12 PM
poncho62's Avatar
Wiki Edits: 5
Should be OK, but they are easy to replace. You just knock out the old ones and put the new ones in using a large socket and a hammer, if you don't have a press.
Old 05-17-2004, 11:05 PM
I wouldn't mix them. I knew someone who did, but only until he could get home & fix it right.
A large punch works much better for driving races out than a small one. Don't know why, I just know it's a whole lot easier.
Old 05-18-2004, 07:44 AM
OK Thanks guys.
I could not get them to budge before, but I will find a way to get them out.
406chevelle
Old 05-18-2004, 09:31 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
Always use new races with new bearings.
Use a long 1/4 inch drift punch from the opposite side and alternate from side to side to keep it going square.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
Old 05-18-2004, 06:46 PM
302 Z28's Avatar
Never use old races with new bearings, or vice versa, unless it's an emergency. The berarings will not last long if you do. If you are installing new bearings and do not think you need to replace the races, why are you replacing them in the first place?
Vince
Old 05-18-2004, 07:30 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
don't forget the heat wrench. works wonders for me.
Old 05-20-2004, 02:17 PM
aka Duke of URL
Unhappy
Use the old bearing cup as an installer. Tap them in with the old cup instead of beating a good socket to death.
