replace power brakes vacuum booster - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-14-2009, 01:47 AM
I have a 1985 Chevrolet C20 pickup with a hissing vacuum booster. My automotive friends tell me the booster needs to be replaced so I disconnected the master cylinder and check valve, but I'm having a little trouble loosening two of the four bolts connecting the booster drum to the firewall. Any hints? Is a special tool required or would a ratchet with a universal joint do the trick? Also wondering how difficult it is to disconnect the booster under the dash from the brake pedal. And are there any pitfalls to watch out for in re-installing the new booster?
All knowledge, experience, and ideas gratefully received - leprechaun
Old 08-14-2009, 08:10 PM
fast68's Avatar
likes chevy trucks & boobies
not that bad to do i have removed billions of them from so many of these trucks ive junked and whatever over the years you will need a universal 3/8" adapter and socket and extensions and soak the hell out of the nuts with PB blaster etc
the rod on the brake pedal arm is easy youll see when you lay on your back on the floorboard its no big deal at all
two of the booster nuts are more difficult
you just have to work at them
youll get them
dont worry
the new booster will slide right onto the studs easily no issues there either
if this truck has cruise control then make sure the sound is not actually from the vacuum hose at the brake pedal switch
some ppl mistake a bad booster sound for a bad cruise break switch
most of the late 70s and 80s trucks did have cruise control
if the brake pedal is easy(dont have to stand on the pedal with both feet to stop the truck) and it holds about 3 pedal pumps worth of vacuum after the engine is stopped then i would probably just leave it be
gm boosters are not well known for failing, it is a rare occurance for them, it is the fords that usually fail often,
in my own experience that is.,, over the years of wrenching and owning all different kinds of old trucks.,
i have owned over 200 different vrehicles since 1994 and ive only come across maybe three bad gm boosters ever
the last one was in an 83 caprice classic with under 100k miles
i found a new reman booster in a junkyard on another caprice for 40 bucks and i changed it promptly because i bought the car for cheap this way from an old guy and it was a clean creampuff and you had to stand on the pedal with all your weight to stop it ahha.
the car ones are so much more difficult to replace than the truck ones because the nuts are under the dash in a bad place
the truck ones are cake walk
welcome to the forums
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 04:00 PM
running no vacuum advance oregon chevelle Engine 28 02-07-2007 08:17 PM
No ported vaccum port in my Q-jet, help Augusto Engine 11 12-27-2006 06:04 PM
Ported Vacuum 72Orange Engine 18 08-07-2006 09:56 PM
converting standard brakes to power on a 55 belair Randal4h Suspension - Brakes - Steering 5 09-15-2003 12:45 PM
