Replace Rubber Flex lines on not - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2012, 11:54 AM
I'm installing a 2001 Chevy S10 Blazer Disc brake rearend that has two rubber brake lines, one for each side. Both lines are in excellent condition no cracks or rub marks, should I replace them now? I would like to replace them but all the replacements are Chinese and I've had some bad experiences with Chinese brake parts, had 2 new Oreillys rear wheel cylinders fail within a month and one brake light switch leak.
Should I keep the original USA lines or use the Chinese?
Old 09-26-2012, 12:16 PM
malc's Avatar
Born To Be Mild
I bought stainless braided replacements from Summit.
Check these out.
Not sure if they´ll fit your year though.
Old 09-26-2012, 01:55 PM
delawarebill's Avatar
brake lines
for me, i'd be keeping the orig as long as they are good cond.. as u mentioned u have an '01 chebby.. have u ck'd the brake tubing from the m/c that run along the top of frame ???? your in a good yr that chebby had major rusting of bk lines..'99-'07
Old 09-26-2012, 10:27 PM
Not that I like using chinese made junk but I have used parts store replacement hoses on a few different occasions now without an issue. In some cases thats all you can get anymore if the oem parts are not available or prohibitively expensive.
if the original hoses arnt swelling/soft/mushy/dry rotted and the end fittings if there steel instead of brass arnt rotten/rusty and ready to crumble apart (had a few hoses fail that way) I'd reuse them.
ethanol and rubber fuel lines ogre General Rodding Tech 8 06-24-2012 07:48 PM
Bad rubber fuel lines ScoTFrenzel Hotrodding Basics 4 01-06-2009 02:48 PM
Routing Front Brake Flex Lines steve392 Suspension - Brakes - Steering 3 12-22-2007 02:28 PM
Rubber transmission lines? HotRodMan Transmission - Rearend 1 10-21-2006 09:37 PM
front brake flex lines stea Suspension - Brakes - Steering 3 07-06-2004 08:10 PM
