replace a t-350 detent cable?
how do I change the kickdown cable on a th350 in the car
Remove cable from carb or accelerator pedal.
Remove retainer bolt on side of trans case. Pull up on cabel housing to unseat. Remove cable end from detent linkage wire, carefully. Reverse process to install. |
If the replacement cable has a rubber sealing sleeve.... the sleeve goes into the trans case first.
lube the cable end and then push it into the case after hooking the cable end to the trans link.
At the Bonneville Salt Flats, first gear is known as 130 mph. |
| 700 R4 tv cable hook up at carb | murrsue | Transmission - Rearend | 4 | 10-18-2006 09:50 AM |
| E-Brake Cable | MI2600 | Suspension - Brakes - Steering | 10 | 06-01-2005 10:15 PM |
| tv adjustment..i know!? | pink63impala | Transmission - Rearend | 5 | 03-10-2005 10:34 AM |
| stuck detent (kickdown cable) | dawg | Transmission - Rearend | 2 | 09-20-2004 09:58 AM |
| Th 350 Detent problem | saenz5 | Transmission - Rearend | 2 | 03-02-2004 07:14 AM |
