replace tranny or go with a gear vendors overdrive? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-09-2010, 12:00 PM
Guys,
With winter approaching, I'm beginning to think about what to do with the car in the off-season. I have been wanting to replace the tranny for a overdrive unit to help with cruising, but I recently have been looking at the gear vendors ad-on overdrive unit as an option. I have a 69 mustang with a toploader and wanted to know if anyone has any advice for me. The car has a worked 302 with nitrous that makes about 500 hp, but I only seldom race. If I go with a tranny, does anybody have any advice with regard to brand, 5 vs 6 speed, specific gear drive ratios for various gears, and whether or not I should go with a proshifted box. Thanks for any advice.
Mike
Old 09-09-2010, 12:49 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Check the installed length of the gear vendors unit as it does take up some space to install it..Saying that it is a good unit.
you may wish to look into a Tremec or a richmond gear unit and get the overdrive that way..I would stay away from a proshifted unit unless it is a drag only car as those can be a bit difficult for use in a road car but that is more a personal thing..In any case look at the torque rating of the trans unit before purchase in order to get one that has a chance of holding up..
Sam
Old 09-10-2010, 10:04 PM
Call Keisler.I have dealt with them several times.Pretty well thought out set up.I doubt a t56 or gear vendors will go in without floor mods.I would personally like to try one of the gv units someday.Splitting the gears sounds like lots of fun.
1985 chevy 4x4 tranny problem in 3rd gear 85chevystepside Transmission - Rearend 1 08-31-2010 10:58 PM
7 hours, 33 phone calls, &30 pages of Threads later... Rearend? Tranny? Need Guidance 68ChevelleFromHell Suspension - Brakes - Steering 19 01-13-2006 01:01 PM
REPLACE FLATHEAD 6 WITH OVERHEAD 6 (60's - 70's) AND TRANNY sifua Engine 1 08-16-2003 05:39 PM
c4 tranny won't go into gear KoNFuZioN Engine 3 07-07-2003 01:36 PM
Gear Choice... need to replace 4.62's USMCDCC Transmission - Rearend 7 02-12-2003 01:01 PM
