Replaced brake booster now pedal comes up slow - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-05-2010, 02:37 PM
Hello guys I have a 96 s10 and just replaced my brake booster as the old one had a internal leak. I had to take the master cylinder off lines and all to get my new one on. All of the fluid in the master cylinder was drained out and after everything was all reinstalled I bleed my brakes several times till just to where fluid comes out of the lines.
When i take out my truck it has nice grabbing brakes but the pedal does not come back very fast and it takes about 4 to 5 seconds. It never did that before so what can I do? Master cylinder was just fine before this and had no issues. Pedal does not go clear down to the floor it goes down about the normal distance and is just slow coming back up.
I put the shims that was on the master cylinder bolts back on and everything is the same as before. Also my s10 does not have anti lock brakes as to all of my lines where all replaced with all new steel line and the original proportion valve was replaced with an aftermarket one.
All was good till I replaced the booster.
Thanks guys sorry for asking but seems like one thing after another.
Eric
Old 09-05-2010, 03:54 PM
LATECH's Avatar
Last journal entry: New Gas Tank
sounds like an internal vacuum problem in the booster. If it was a cardone I would lay money on it being defective.
Old 09-06-2010, 04:49 PM
Well latech I went ahead and got a replacement and it did the trick. It was a cardone from advance auto. I did a lot of reading and it all pointed to the booster which sucked cause it too some time to get it on then off again. Well take care.
Eric
Old 09-06-2010, 07:58 PM
LATECH's Avatar
Man I hate cardone. It can screw up your flat rate to do it twice and get paid once.
Glad to help.
Old 09-07-2010, 03:12 PM
Yeah its sad nowadays on the crappy parts you get. The main problem is quality control and checking of stuff. Take care
No consistent brake pedal risaacp Suspension - Brakes - Steering 15 10-21-2006 06:46 PM
brake pedal to the floor!? troubleshooting customdrumfinishes Suspension - Brakes - Steering 6 10-13-2006 12:23 PM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
Brake pedal Clunk montea Suspension - Brakes - Steering 3 05-19-2004 08:34 PM
brake pedal does not return completely 49burb Suspension - Brakes - Steering 7 03-29-2003 05:34 PM
