Replaced T-400 and have the same problem - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-26-2013, 08:50 PM
Originally Posted by RWENUTS View Post
Put the base of the angle finder on the flat part of the yoke where you see the cup of the u-joint. Put the flat part of the yoke down. Put the rearend of the car up on some blocks under the tires so the suspension is loaded. After it's on the blocks bounce it so it's settled before measuring. Block the front tires so it won't roll away.
In this link posts 11 and 19 show where to put the angle finder.
How much is too much stock driveshaft angle - Jeep Wrangler Forum
Just what I needed! Thanks!
T-400 problem TJ555 Transmission - Rearend 11 10-18-2012 05:13 PM
T-400 problem again cletus van damme Transmission - Rearend 4 05-15-2010 03:07 PM
T-400 problem cletus van damme Transmission - Rearend 3 11-08-2009 01:32 PM
400 TH Problem? reflog Transmission - Rearend 6 07-16-2008 07:39 AM
Replaced Brushes & replaced battery terminals 78novaman Electrical 1 10-01-2006 07:39 PM
