Replaced T-400 and have the same problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-24-2013, 07:52 AM
Hi,
I'm new to this forum and saw some good info and am hoping for some help. Sorry this is so long. I have a 57 Chevy with a 350, mild cam (i don't know specifics since I didn't install it), turbo 400 and 355 rear end. The car has always shifted hard into second gear (thumps) when I drive it slow. First shift is fine then every one after is bad. If i give it some gas it's fine. I checked vacuum which is 15 and even replace the modulator with an adjustable one and no difference.
I decided to replace the transmission and installed it and a 2200 - 2400 stall converter. After $1500 and 10 hours installing it by myself, it does the same thing! I'm besides myself. I've asked some local shops and I get everything from I don't know to that transmission is too big for a small block. We don't have a lot of shops in my area that deal with cars like this. I don't know what to do. Any help will be appreciated.
Old 09-24-2013, 09:08 AM
Speedshift_Sam's Avatar
Mekanicus Automotive Group
Hmm, puzzling.
By no means is that 400 too big for your sbc. We have two motorhomes with 400 small blocks and 400 trans' behind them. I also had a pickup with a TH-475. All of them shift a little hard into second if you are "*****-Footing" around. They are heavy duty transmissions, and built to take some very severe thrashing. Since they are a Vacuum controlled kickdown, have you checked your lines? One could be kinked or slightly plugged.
Old 09-24-2013, 01:37 PM
Yeah I did check the line. I just got a hold of the tech at the company I bought the transmission from. He is sending me a spring to put in behind the modulator? I'm really a novice at transmissions so am not sure what this will do but am going to try it.
Old 09-24-2013, 02:27 PM
Faith - Respect - Trust
You mentioned you had a 3:55 rear end...Where did the diff come from and who installed it? Also, how long have you had the car, if it's been a while, are you going through U joints quickly?
Just reading your posts, if the rear end is a donor from another vehicle, you may want to check the pinion angle...it could very well be that your transmissions are fine, but, with an improper pinion angle, it is possible to get a hard shift feeling if not under load.
Something to check
Ray
Old 09-25-2013, 05:26 AM
Something to check
Ray
The rear end is a stock housing from the 57 so I'm told. It was in there when I got the car. I've had the car for 5 years. No u joint replacement but you make a good point. Can you tell me how to check this?
Old 09-25-2013, 08:03 AM
RWENUTS's Avatar
Is your tranny side mounted or rear mounted? Is the motor front mounted or side mounted?
Stock was motor front mounted, tranny side mounted.
Your motor/tranny might be moving a bunch causing the clunk.
Here's a link with a chart and a video on pinion angles if you need it.
Pinion angle? - The 1947 - Present Chevrolet & GMC Truck Message Board Network
Old 09-25-2013, 08:35 AM
Great post reference! Thanks
Old 09-25-2013, 08:52 AM
RWENUTS's Avatar
BUt the question remains, how's your motor/tranny mounted?
Old 09-25-2013, 08:56 AM
Sorry, I'm trying to do this at work. The motor is side mounted and the transmission is rear mounted.
Old 09-25-2013, 09:16 AM
RWENUTS's Avatar
Good!
Could be pinion angle then. Here's a link to a good angle finder for checking angles.
Swanson Tool Magnetic Angle Finder - AF006M - Swanson Tool Store
Old 09-26-2013, 01:27 PM
I thought the 400's had electric kickdowns?
peace
Hog
Old 09-26-2013, 03:39 PM
First of all I'm not saying it is pinion angle...just that it could be. The angle checker that "RWENUTS suggested would work fine and it is a place to start.
The pinion angle is something that you may want to check...I usually set mine between 4 and 5 degrees but, everybody has a different opinion of the pinion so I tried to do a bit of research and some of the best information I found was right here on this site.
Pinion Angles and Driveline Setup for the Street
Some good information on pinion angle and how to check it and set it up...also on a few other threads...what can happen with a bad pinion angle.
Check out the thread and your car...I sincerely hope this helps.
Ray
Old 09-26-2013, 07:03 PM
I purchased a magnetic angle tool. I'm really a backyard mechanic so bear with me. Do I set this at each end of the driveshaft and see what it reads? My car is lowered so I can't get under it without jacking it. Do I need to put something under the wheels so it is level? Sorry if these are dumb questions.
Old 09-26-2013, 07:21 PM
RWENUTS's Avatar
Put the base of the angle finder on the flat part of the yoke where you see the cup of the u-joint. Put the flat part of the yoke down. Put the rearend of the car up on some blocks under the tires so the suspension is loaded. After it's on the blocks bounce it so it's settled before measuring. Block the front tires so it won't roll away.
In this link posts 11 and 19 show where to put the angle finder.
How much is too much stock driveshaft angle - Jeep Wrangler Forum
Old 09-26-2013, 08:48 PM
What I have done in the past is check the angle of the tail shaft of the transmission. The angle that the transmission is sitting at will give you an idea of what the pinion angle should be offset at. Sometimes, I've seen factory diff's installed at 0, or 1 & 2 degrees. If your 350 and TH400 where installed perfectly level, you won't have enough angle and will not have enough load on the drive shaft...I try and install engines at 4 or 5 degrees and offset the diff accordingly...again, others may disagree and I would welcome other opinions...but this is what I've done, had success, I've seen drive trains installed with virtually no angle and problems arise.
Hope this helps
Ray
T-400 problem TJ555 Transmission - Rearend 11 10-18-2012 05:13 PM
T-400 problem again cletus van damme Transmission - Rearend 4 05-15-2010 03:07 PM
T-400 problem cletus van damme Transmission - Rearend 3 11-08-2009 01:32 PM
400 TH Problem? reflog Transmission - Rearend 6 07-16-2008 07:39 AM
Replaced Brushes & replaced battery terminals 78novaman Electrical 1 10-01-2006 07:39 PM
