Several people have asked me about replacement pumps for the vary popular 60 gallon single stage compressors of 6-7 "peak" HP rating. These things almost always have a 15 AMP motor of 3 true HP and produce around 10-11 CFM@ 90 PSI (even though they may claim a bit more than that). These pumps are usually hard to find in this CFM range but I have noticed that Surplus Center now has some and at a bargain price These are DeVilbiss inline two cylinder single stage pumps with cast iron cylinders that should produce over 10 CFM@ 90 PSI and should fit most if not all commonly found compressors of this type such as Campbell Housfeld and others. At only $99.95 they should be a real bargain. I am not trying to sell compressors for anyone it is just that I think this is a good deal for someone thinking of rebuilding or just refreshing their older compressor. If your motor is good and all the other parts are in working order then this can be cheaper than buying a new compressor.www.surpluscenter.com/item.asp?UID=2006062318324685&item=4-1761&catname=
