Replacing 36 chev wood frame - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2006, 06:09 PM
I am going to replace the wood inner structure of my 36chev tudor with steel but am not sure of what and how much i need. I was going to use square tubing but just how much do i need?
Any help would be appreciated.
Chuckk
Old 09-27-2006, 10:06 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Do you men how many linear feet of tubing? If so, get out your trusty tape measure, a pencil and paper. Sketch out all the tubing paths you will be installing, measure those paths on the actual car body and you will have the number you need. Buy ~10% more than you need to allow for mistakes, mis-calculation.
Old 09-28-2006, 09:06 AM
I meant what size of square tubing and do i need to totallybuild an inner structure.
Old 09-28-2006, 10:17 AM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Take a look at this thread:
How To Go About Replacing Wood With Steel In 34' Chevy?
Old 09-28-2006, 08:07 PM
Wiki Edits: 21
As mentioned in the other thread, choose a tubing size that best replicates the wood that you are removing. 1 1/2" and 1 1/4" square and various rectangular sizes will be used a lot.
One word of advice; the question was asked in the other thread, "why not just replace the wood?" There are so many good reasons to use steel instead of wood I don't know where to start. With steel the doors will be WAY lighter and stiffer so they won't sag as they immediately do with wood. The body will be very stable and keep its shape which it won't do with wood. In short, don't even think of replacing the wood with wood.
Replacing wood bracing in cab 35chevy Interior 6 02-07-2006 11:01 PM
Replacing camaro rear frame rails 72camaro Body - Exterior 6 05-28-2003 04:54 PM
Looking to Purchase Wood Frame for 1935 Chevy Pickup xprs Interior 1 11-16-2002 02:26 PM
replacing a hunk of frame axle bastard Body - Exterior 5 08-21-2002 09:50 AM
9" ford in 48 chev frame fat48chev Body - Exterior 7 06-30-2002 08:37 AM
